Old 08-25-2015, 11:47 PM
med.3012's Avatar
med.3012 med.3012 is offline
Gold Member
Just to put the scope result from a previously proposed circuit if CD connection is closed, the test used under high voltage, taking the voltage across safety distance using another pickup coil.
this is the proposed circuit :
this is the result :
this prove the importance of using the E-TBC if CD is closed, the oscillation increase when passing through zero volt which indicate the importance of the third parameter which is R , this is the super conductivity in room temperature ( another kind of negative resistance ). for better results it's vital to look for direct resonance !
