Was there a technical acknowledgement time stamp for
the 9:23 message?
It's great to see such a quick response to such a relevant question.
Hi,
The instructions on how to decode the data is in our article.
"The underlined date and time is when the message was received by the airplane. "
DDLXCXA CHIAK CH158R
.CHIAKUA DA 111323/ED
CMD
AN N612UA/GL PIT
- QUCHIYRUA 1UA175 BOSLAX
- MESSAGE FROM CHIDD -
/BEWARE ANY COCKPIT INTROUSION: TWO AIRCAFT IN NY . HIT TRADE C
NTER BUILDS...
CHIDD ED BALLINGER
;09111323 108575 0574
So to answer your question... yes. It was received according to the data.
Hope this helps.
Rob Balsamo
Co-Founder
Pilots For 9/11 Truth
Full member list at
Pilots For Truth List Of Members
Photos here
Patriots Question 9/11 - Responsible Criticism of the 9/11 Commission Report
Some have further gone on to speculate that United Airlines Dispatchers routed the messages themselves based on flight planned route. Flight Tracking protocol as described renders this argument moot as
the Dispatcher does not have control over ARINC routing of ACARS messages through remote ground stations.
This type of premise is the equivalent of saying that when you call someone from your cell phone, you have the capability to choose which cell tower around the world you want your call to be routed. It's absurd. But for the sake of argument, we will explore this hypothesis.
Dispatch Operations Centers monitor flight tracking of the aircraft in near real time on an Airspace Situational Display (ASD). The United Airlines ASD is refreshed every 60 seconds according to another Memorandum For The Record released by the 9/11 Commission(4)
When asked about the technical capabilities of the ASD (airspace situational display) program used by the dispatchers on their monitors to track planes, all United representatives conferred that the program's display refreshes every 60 seconds.
ACARS CONFIRMED - 9/11 AIRCRAFT AIRBORNE LONG AFTER CRASH
McCurdy recollected that at the time of the crash into tower 2, the display on Ballenger's monitor still showed UAL 175 at 31,000 ft, having just deviated from the normal flight plan and heading into a big turn back east.
The reason Dispatchers have an ASD is due to the fact the aircraft across the globe deviate from their cleared flight plans daily due to weather, traffic, etc. With an ASD, Dispatchers can keep track of their flights and alert for weather (or other adverse conditions) along the route.
Even if Dispatchers had the capability to choose which specific ground station to route a message, why would they choose MDT and then later PIT if the aircraft is diverting back to the east on their monitors? The answer is, they wouldn't. The hypothesis that Remote Ground Station routing is based on original flight plan
is completely absurd and usually attempted by only those who obviously are not interested in the facts, instead need to speculate to hold onto their beliefs. As described, the Central Processing System routes messages through remote ground stations based on Flight Tracking Protocol(5).
PENTAGON
9-11 Here's something the government didn't want you to see - YouTube
Other researchers with knowledge of this said flight 175 was in the air after the explosion. I'm saying that NO commercial airliner crashed into tower 2. And, that
only a small object can be confirmed with some tight corroboration as the true thing present before the explosion.
http://pilotsfor911truth.org/ACARS-C...TER-CRASH.html
UNITED 175 IN THE VICINITY OF HARRISBURG AND PITTSBURGH, PA
The first message at 1259:19Z, as stated, was received by the aircraft, but not crew acknowledged, which is not required as technical acknowledgements are automatic. This is referring to the message noted above sent through MDT by Jerry TSEN (First coded ACARS message at top). The second (1259:29Z) and third messages (1259:30Z) referenced in the MFR were not provided through the FOIA. The last message (1303:17Z) referenced in the MFR is claimed to not have been received by the aircraft according to the 9/11 Commission. However, all we have is their word, which contradicts the statement made by Ballinger and the Technical Acknowledgement time stamp. The coded Rogers initiated ACARS message is included above, third from the top. Of course, the 9/11 Commission cannot admit if the last message was received by the airplane as that would immediately indicate to anyone that the airplane did not crash into the South Tower at 09:03am.
It is interesting to note that the Commission ignores the 9:03am ACARS message sent by Ed Ballinger routed through MDT (second ACARS message printed above), yet claims the 9:03am message sent by Rogers as not being received. Based on sequential numbers of the messages themselves, it is clear Ballinger's 9:03 message was sent before the Rogers message (0545 for Ballinger message, 0546 for Rogers, printed on bottom of the message), yet the Commission ignores Ballinger's message. Why would they ignore Ballinger's message, yet acknowledge Rogers? Is it because Ballinger's message was received by the airplane and they realized that an aircraft cannot receive an ACARS message at that distance and such low altitude?
This message is more evidence the aircraft was in the vicinity of Harrisburg, and not NY. At least 3 ACARS messages were routed through MDT between 8:59 and 9:03am, and
received by the airplane, according to the technical acknowledgement time stamps at the bottom of the messages.
The last message sent at 9:23AM, routed through Pittsburgh, has been completely ignored by the 9/11 Commission as well. Although important to know whether the messages were received,
it is equally if not more important to understand how they are routed, received or not.
Based on Flight Tracking protocol,
the only reason the Central Processing System would choose to route messages through the ground stations located at MDT, then later PIT, over the numerous ground stations much closer and surrounding NYC,
is due to the aircraft being in the vicinity of MDT, and then later, PIT. This means that the aircraft observed to strike the south tower, was not United 175.
