Old 07-22-2015, 07:01 PM
BroMikey's Avatar
BroMikey BroMikey is online now
Platinum Member
Originally Posted by Abdullah View Post
Free Energy Generators
I tried to do the same thing as in the above link but it didn't work with me I brung the electric board switches with plug of 3 poles, lighter spark generator I turned the wire of the electric switches more than 8 turns with the switch on the ON position and plugged the electric plug in the switch and sparked by the lighter sparker on the earth pole, but it didn't work the electricity will not circulate in the electric switch board.
does this way of generating electricity needs wires of certain thickness or certain wire length? what shall do I do so that I can generate electricity the same way in the above link?
Abdullah
Hello Abdullah
That is a good question, I saw Lasersaber show a video one time
with these strips and he said there was a little more to it. The
energy was made to recirculate. But I don't know how much power
is working in the circuits. Lasersaber said he could not give the
answer as to how it worked at that time but maybe later he would.
Since then i have not heard anything about it. It was something
put inside to oscillate or regulate the circulating energy in pulses.
Then according to aetheric speculation the HIGH VOLTAGE at the right
tuned spot draws radiant into it. The energy just shows up at the load.
Thats right the energy just shows up in the load section of the device.
I know it is a weak worthless thought I have just tried to relay but
is the best I can do, I am a lost beginner.
Most really experienced scientist just see this device and call it a hoax.
I am here learning because I know that the possibilities for energy
producing devices are infinite.
