Grounding
Hi,
Any advice the grounding network? I think this is the most critical part (my previous effort didn't work because of that). What is the spacing between the rods? I might only be able to go about 6 feet because I might hit bedrock; I read the spacing should be twice the rod length. Is there a way to check if the there is enough ground rods by checking the resistance between the neutral post at the inverter and the captor ground terminal?
