Old 04-13-2015, 06:55 PM
level level is offline
Senior Member
Originally Posted by totoalas View Post
Have you checked the earth resistance of the three set of rod connection so we can have an idea if ever we are near to your arrangement....???
Hello totoalas, on the schematic it shows that the two outer sets of grounds of 28 rods each are all wired together, so they are really one set of ground rods. The other set of ground rods is the 4 grounds in the center which are tied together. I don't think Clarence has posted a diagram of his current ground rod layout, but Clarence posted an earlier ground rod layout in the diagram that is attached to this post:
http://www.energeticforum.com/273531-post4.html
@Clarence, I think totoalas was asking what the measured resistance is between the input and output set of ground rods you have installed, as a rough idea of how much resistance there is between your two sets of ground rods. I don't know if a typical multimeter can measure earth resistance very reliably, but it might still give a rough idea for comparison purposes.
level
