Old 04-13-2015, 06:27 PM
clarence's Avatar
clarence clarence is offline
Silver Member
Originally Posted by a.king21 View Post
Thank you Clarence for surfacing publicly again.
It would be good science if you could post some of your run times and start and finish battery voltages.
I am in a position to replicate as are others because we have the land space.
Did you do any prior experiments to validate Barbosa Leal or did you just go for it?
I know that Lasersaber has noticed your replication and I am sure he is duplicating.
Hello a.King21,
After I read the B&L patent back and forth SEVERAL TIMES and began to pick
out the important information and discovered the slick way they had disguised some facts, I just did it. the only place I screwed up was that I
did't catch the hidden deception about the transformer type used. just like a big dummy I used a MOT and THAT was a definite FARCE! I smoked a set of looped secondary wires into VAPOR in less than 5 seconds with a single 7AH
battery!! that was a BIG --O S---! I did some more reasearch and found that they were Actually using Toroids. so I've been good ever since.
the next later thing I learned was that I simply needed a LARGER AH battery.
I already they knew they were using the Captor output to self run the device - they openly said so various times. that wasn't a hidden secret
as far as I'm concerned. the charger keeps the batt at 12-13 v up and down.
my location here for ground potential is lousy to say the least and at times
even with sixty rods I can tell that I need another 10 to 20.
when it rains here the potential drops off to under the needed rms voltage
to consistently carry higher loads. and it has been raining here the last 3 days. so what that does is keep the charger from max performance
power wise and the battery voltage because of it will ever sooooo slowly
drop. the last time during rain time I ran it for over 4 + hours and it went
from 13+ to 12 so i removed the loads and let it charge.
so you SEE I have to take my OWN advice about how to MAKE SURE that enough rods + about ten more or so are in place to prevent problems!!
BUT know definitely that this type unit is a winner.
Hope all that helps. I did not mean to ignore you - the time delay was because i simply overlooked your post . I apologize for that Sir.
Thanks for listening.
Clarence
