  #4 (permalink)
Old 02-25-2007, 08:34 AM
Aaron's Avatar
Aaron Aaron is online now
Spiritual Entrepreneur
Analysis by John Bedini PART 3
Now read the story this way, <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
<o:p></o:p>
The hall effect transistor is to activate sw1 I use a solid state relay for sw1 The circuit will need a battery for power source.. Their are some modifications needed for acheiving unity, then you can get rid of the battery Yes feedback, and play with sw1 timing I must tell you I use the third winding on my stator coil as a generator winding to charge the cap up from 0v, then when the transistors begin to pulse the back emf through sw1 brings the voltage on the cap even higher till it levels and the motor is then runing at unity,but I always stop it after a few hours or so. look at the commutator to see the timing ,("""ss relay puts the main winding in series with the third winding at the correct time, take into account the rectifier diode in between them""".) I don't know if all is needed for the circuit.I just know that this is how I got it to run longer. how long I dont know so far maby a couple hours. I belive it is working at or near unity. I know that the third winding charges the cap.("" and I think somthing coming through the ss relay helps this charge"").what I did after getting my motor to run without any mods.<o:p></o:p>
I would use it to charge a second battery hopeing I could switch the batteries over and over and it would run for ever, this was not the case, then I found out that if I charged a large cap up with it the motor drew less current from the battery. this was with sw1 between cap+ and bat+,,monitor your input current with diffrent caps to see what works best.<o:p></o:p>
-------------------------------------------------------<o:p></o:p>
Now read the story this way, Do you all get it now.<o:p></o:p>
John<o:p></o:p>
<o:p></o:p>
<o:p></o:p>
The hall effect transistor is to activate sw1 I use a solid state relay for sw1 Yes feedback, and play with sw1 timing I must tell you I use the third winding on my stator coil as a generator winding to charge the cap up from 0v, then when the transistors begin to pulse the back emf through sw1 brings the voltage on the cap even higher till it levels..ss relay puts the main winding in series with the third winding at the correct time, take into account the rectifier diode in between them. I belive it is working at or near unity.I know that the third winding charges the cap.("" and I think somthing coming through the ss relay helps this charge"").what I did after getting my motor to run without any mods.<o:p></o:p>
The answer.<o:p></o:p>
ss relay puts the main winding in series with the third winding at the correct time, take into account the rectifier diode in between them. I belive it is working at or near unity.I know that the third winding charges the cap.("" and I think somthing coming through the ss relay helps this charge)<o:p></o:p>
to be continued in next post...
