Old 12-10-2014, 11:27 PM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
Originally Posted by SYDERA View Post
Does one have to hack if an aberration is part of the chaos or chthonic nature- in the female form if you get my drift?
Can your hacking method adopt my creative dance? Can it be mapped?
Somethings cannot be predicted
References in psychology and anthropology[edit]
Chthonic - Wikipedia, the free encyclopedia
In analytical psychology, the term chthonic was often used to describe the spirit of nature within; the unconscious earthly impulses of the Self, that is one's material depths, however not necessarily with negative connotations. See anima and animus or shadow. Gender has a specific meaning in cultural anthropology. Teresa del Valle in her book Gendered Anthropology explains "there are male and female deities at every level. We generally find men associated with the above, the sky, and women associated with the below, with the earth, water of the underground, and the chthonic deities."[3] This was by no means universal and in Ancient Egypt the main deity of the earth was the male god Geb. Geb's female consort was named Nut, otherwise known as the sky. Greek mythology likewise has female deities associated with the sky, such as Dike, goddess of justice who sits on the right side of Zeus as his advisor. Eos was the goddess of dawn. Hades is the ancient Greek god of the underworld.
... Genes tell story of birdsong and human speech ... Listen Here
The world soul (Greek: ψυχὴ κόσμου, Latin: Anima Mundi) is, according to several systems of thought, an intrinsic connection between all living things on the planet, which relates to our world in much the same way as the soul is connected to the human body.
The idea originated with Plato and was an important component of most Neoplatonic systems...
Similar concepts also hold in systems of eastern philosophy in the Brahman-Atman of Hinduism, the Buddha-Nature in Mahayana Buddhism, and in the School of Yin-Yang, Taoism, and Neo-Confucianism as qi.
Numbers are the sources
of form and energy in the
-Theon of Smyrna (Second
century A.D., Platonist
Number . . . should not
be understood solely as a
construction of
consciousness, but also as
an archetype and thus as a
constituent of nature both
without and within
-Marie-Louise von Franz
The temperature inside The Great Pyramid remains constant at 68 degrees F
Wave propagation occurs when high-pressure compression waves push against areas of lower pressure in the atmosphere. Sound waves move at the speed of sound (1130 feet per second at sea level and a temperature of 68º F).
MUM 2600 – Chapter 2 Notes
This short statement comprises a concise explanation of the main infrasonic function of the Great Pyramid --global infrasonic synchronization of the collective human consciousness, thereby endowing feminine forces: vi Sani raua ra Yoni --"From masculine force, thundering, granting feminine."
"Know masculinity, Maintain femininity, and be a ravine for all under heaven." (chap. 28, tr. Mair)
<º)))>< .... Spiral
"Avoid extremes-keep the Golden Mean."
-Cleobulus of Lindus (sixth century B.C., one of the Seven Wise Men
of ancient Greece)
Orphic Egg - Wikipedia, the free encyclopedia
Know, therefore, that in the hen's egg is the greatest help with respect to the proximity and relationship of the matter in nature, for in it there is a spirituality and conjunction of elements, and an earth which is golden in its tincture.
"Aureus:" The Golden Tractate of Hermes Trismegistus.
The acronym V.I.T.R.I.O.L.U.M., used in alchemical literature, is formed by the Latin expression "Visita Interiora Terrae Rectificando Invenies Occultum Lapidem Veram Medicinam", what means "Visit the interior of the earth, and by rectifying you will find the hidden stone which is the true medicine".
…and as long as you do not have the Wisdom,
die to become,
you will only be a sad guest on this Dark Earth
( KMT ) .
He who wants to enter the divine realm,
first must enter his Mother’s body,
and die herein.
Thus we are invited to descend into the earth, into the underworld, or the unconscious. The earth is the symbol of physical man. Man needs to become conscious of his inner world, who he is, what he is doing, what his motives are, and so on. Once attention is directed inwards, a whole new world opens: the underworld of Hades, the dark realm of shadows and monsters.
This descent is also called ‘regressus ad uterum’, ‘the return into the uterus
The Maya understood the concept of the Zero and represented it as a seashell, spiral or womb centuries before the Hindus had it: 36 BC.
Back to the Womb: Caves, Sweatbaths and Sacred Water
O this Ikesy, too secret for the gods, whose name the spirits fear to know,
which those that enter cannot leave except for this noble god,
who causes fear of him for the gods and terror of him for the spirits.
It is a flame with the air of destruction for nostrils and mouths.
He did it against his following, to prevent them breathing his air,
except for this noble god who is in his egg.
I have come before you to be in your following.
I come and go in Ikesy, and is doors are opened for me.
I breathe the air in it, and have power over its offerings.
Book of the Dead / Journey to the West 149
The Rig Veda (RV 10.121) uses a similar name for the source of the universe: Hiranyagarbha, which literally means "golden fetus" or "golden womb".
Golden Ratio of a Woman's Uterus Is Linked With Her Fertility
Nut's headdress was the hieroglyphic of part of her name, a pot / torus , which may also symbolize the uterus
*A baby's temperature while in the womb remains constant at about the same body temperature as the mother's, which is about 99.86 degrees F
how many stars on nut ...
Strong's Greek: 32. (aggelos) -- an angel, messenger
32 (ággelos) is used 176 times in the NT (usually of heavenly angels)
John 1:1-3 "In the beginning was the Word,"
" Words of Truth that have the power to express the Truth are like flourishing trees whose roots, or direct meanings, are established deep in the earth of the heart, and whose branches, or subtle meanings, reach high into the sky of mystical knowledge." Quran (14:24-27)
The Essene Tree of Life represented fourteen positive forces, seven of them heavenly or cosmic forces and seven earthly or terrestrial forces. The Tree was pictured as having seven roots reaching down into the earth and seven branches extending up toward the heavens, thus symbolizing man's relationship to both earth and heaven.
Man was pictured in the center of the tree half-way between heaven and earth.
Each root and branch of the tree represented a different force or power. The roots represented earthly forces and powers, the Earthly Mother, the Angel of Earth, the Angel of Life, the Angel of joy, the Angel of the Sun, the Angel of Water and the Angel of Air. The seven branches represented cosmic powers, The Heavenly Father, and his Angels of Eternal Life, Creative Work, Peace, Power, Love and Wisdom. These were the Essene angels of the visible and invisible worlds.
The Tree Of Life
the fourteen creative powers of Amun-Ra
.... No agreement
320: Unas' shelter is in his Eye, the protection of Unas is in his Eye,
Unas' victorious strength is in his Eye, the power of Unas in his Eye.
The Pyramid Texts Online - Antechamber South Wall
338: It is pleasant for Unas to be with his ka and he lives together with his ka.
His panther skirt is on him, his ames-scepter is on his arm, his aba-scepter ( Sekhem scepter - Wikipedia, the free encyclopedia ) in his hand.
... Gerson King Combo - God Save the King
