Originally Posted by spacecase0
I can't find anything that creates forces like gravity than the asymmetrical capacitor,
it may not be additive, but gravity can sure be overcome with it,
I think the best path is to use electrostatic induction to make the field,
that way it can't arc over
There are many ways to harness the asymmetrical capacitor and electrostatic induction would maybe improve efficiency reducing corona discharge. I have learned that high voltage pulses applied to materials with odd nuclei spin values (bismuth, barium titanate, mercury) will generate repulsion forces. I also found a patent called "ether propulsion system" that involves placing many metallic needles on an insulated board all connected in series. When they are charged with high voltages from only the negative terminal of a transformer they produce a force proportional to the voltage, surface area and number of needles. An asymmetrical arrangement of needles certainly would make for a great experiment!
