Old 10-08-2014, 09:59 AM
FuzzyTomCat's Avatar
FuzzyTomCat FuzzyTomCat is offline
Silver Member
Send a message via Skype™ to FuzzyTomCat
Originally Posted by parkham View Post
I'm confused by all this. This thread COP 17 Heater | Rosemary Ainslie has the following quote.
I've just discovered this and have been reading for a few hours. Does the original circuit shown in the Quantum Magazine article work at all, or has it all been just a big waste of time?
Thanks, and sorry if I am missing something obvious.
Howdy parkham,
This is a extremely long subject matter with many twists and turns ..... the short of it is that the Quantum article circuit with a COP 17 does "NOT" work as advertised and never stood up to the scientific method of testing and evaluation. It has been modified numerous times by many other knowledgeable experimentalists here and at other alternative energy forums.
I'm listing some early quotes from Rosemary Ainslie and her endless endeavor.
http://www.energeticforum.com/59001-post169.html
I'm not sure if you are aware of it - but I'm a rank amateur. I really need to own up to this because you'll be expecting a level of technical expertise that I simply do not have. Circuit switches need to be built by others. The only aspect of testing that I'm confident with is the actual power measurements and then only as they relate to this modest little circuit. But - if I have a contribution - it's in that model, which is the thesis in support of that gain. In any event I wont bore you with the details. But if and where I state the obvious - it's only because I hardly know enough to see whether it's obvious or not. So. Please bear with me.
http://www.energeticforum.com/59030-post179.html
I've tested the circuit over a 4 year period.
http://www.energeticforum.com/59119-post205.html
I was never given the results of any of the tests conducted by those accreditors. It was not from want of trying. But I was given their permission to use their names as accreditors in the Quantum article. The reason we simply used that precise experiment for the paper submitted to the IET was to reference their names. I do have the report for BP because we had to conduct those experiments on battey duration. But the context of that report is just on the effect as it relates to battery delivery - and it has got to be the single most boring exercise in all of history. It's object impeccable - but the testing exhausting.
I think the truth is that these companies allocate a certain amount of funding to research. And having found their answers they do not make it public. Presumbaly having paid for their own lab time they rightly regard the results as being their property - or their company's property. We did try and get the results - but failed - miserably.
http://www.energeticforum.com/59369-post262.html 07-06-2009, 01:25 PM
TinselKoala - THE ONLY APPROPRIATE CIRCUIT DIAGRAM that I can assure you is correct is the diagram in the paper. And the flyback diode is a critical part of the system.
The circuit diagram in the Quantum article was prepared by Brian Buckley. I cannot comment on whether it is right or not as I simply cannot read it. I am hoping that Donovan will be able to comment in due course. I don't think he has even seen that article - as published.
But it is definitely required as without it we cannot 're-route' the collapsing fields back to the battery to recharge it.
http://www.energeticforum.com/60279-post511.html 07-13-2009, 07:52 AM
Joit - is your waveform proving TinselKoala's point? Is that 555 switch wrongly presented? To me it looks like it is. In which case, I must apologise to all concerned. Clearly the Quantum article was wrong.
So, to all concerned - to everyone who built the circuit as presented in that article, and if, indeed, it is wrong, my abject apologies. I had a shrewd idea it may have been wrong because, thinking back, a university professor kindly edited the quantum paper prior to presenting it to the IET. And his first recommendation was that we omitted a detailed circuit of the 555 switch as being irrelevant to the claim. Which is why I was reluctant to endorse the Quantum article as being a correct presentation. I just wish, in retrospect, that he had pointed out the error if he had seen such. In any event, it seems that I have been entirely at fault. My own objection to it was due to the lack of the feedback diode - which was the entire subject of the exercise. I knew it was in the apparatus. It certainly was not in diagram.
I would point out though, that my reluctance to admit this prior to ascertaining the fact was due to the person who presented that diagram and assisted me in that first article. He is a good friend and he, like all of us, was 'giving' his time. I was not keen therefore to expose the problem unless I also knew it was a problem. So, if you're reading this, don't even worry. In any event, the blame was not his. I should, at least, have had the circuit vetted - considering my own inability to read such.
So. Many apologies, even to TinselKoala and anyone in the entire world who duplicated that circuit. It is wrongly presented. I am sincerely sorry that I have wasted so much of your time. And Joit - you've put the question to bed. I would be very glad to refund you for your time and trouble - if required - and if I can get the money to you with our exchange control. Just send me an account on the PM system. You've done a very good thing here.
What I do assure you all is this. The switch may have been wrongly drawn. Our own duty cycle application is NOT. I have the experimental apparatus available and it has been checked by EE's even at universities. We have also, over the years, built many different 555 switches and by different people. And there are replicated experiments by others using nothing but a functions generator. And all this prior to publication. More to the point is that the battery duration is consistent with measurements based on the duty cycle. But, in point of fact, after publication I never experimented again for a period of 7 years and I certainly never even looked at the article again. The only reason I could scan a copy for the blog when I eventually did this, was because my children kept a copy of the original publication. I was just so dejected at the entire lack of interest it seemed to generate. I had no idea that the test would really ever be duplicated.
Therefore, please take this admission as a sincere apology to all those who have tried to build the switch according to the quantum article. I see that the Quantum article was the primary reference point as the IET paper was only posted to the blog after July. It seems that Ramset and TinselKoala started their thread on OU.COM in mid June. Unfortunate. But there you are. Sorry guys - It's all I can say.
Well we can do this for days, months ..... no years. It is a excellent circuit to keep ones interest up depending on whom you converse with and not her nameless unsubstantiated imaginary experts.
Best,
Fuzzy
Open Source Experimentalist
