Hi Peter et all
Please see my answers below.
Originally Posted by Peter Lindemann
Shad, please tell us more about your "neutrino-egg" device. What is it?
It is a device in which a neutrino-diffusion-process occurs.
I gave it the name according to the theory of Prof. DDr. Meyl (
www.k-meyl.de) who claims that neutrinos are scalar-waves, such as Dr. Tesla had described them.
It received the ‘nickname’ neutrino-egg from Stefan Hartmann from Berlin (
www.overunity.com), after he viewed and published video-material of my experiment.
The first Neutrino-diffuser (ND) was egg-shaped.
In simple words, the dielectric charges in this device are converted to mechanical energy.
What is its primary purpose, since extinguishing light bulbs at a distance was an unexpected side-effect?
The main purpose if my ND is to convert liquids from their liquid state of aggregation to gaseous.
You can see a very simple description on my (purposely simple) website:
http://www.geocities.com/waterpowers/FuelCracker.html
I cannot give any further technical data to this device as I am bound by contract I have with industry. But the physics I can reveal is much more important than the technical data.
How do you run it?
With a pump. My toy model was run a windscreen-water-pump for cars, ca. 12V/10W.
Gasoline, kerosene, diesel or even water are converted to gas - the process is cold, no heating/warming effects. This process is highly efficient; to achieve the same results with heat or mechanical energy one would have to invest ca. 5x more energy.
Gas can be produce on demand.
Have you come to a deeper understanding of the effect at this point?
Yes, and this is the important part of this message.
The atoms have a dielectric charge, not electromagnetic, as we all might have learned in school. The electromagnetic charge is produced by the manipulation or proper interaction of these dielectric charges. The atoms communicate among each other and are in constant exchange with this energy. They vibrate or oscillate and in this way become sender and receiver of this energy. They have a memory on how much energy they received and sent off. The atoms are a kind of ‘cosmic wind-mills’, which constantly absorb energy from vacuum, transform it and ‘radiate it off’. (forgive my funny English…)
If the atoms are artificially triggered, as an example here, in a mechanical way with molecular friction and fluid-dynamics, they will absorb a much higher amount of dielectric charges and ‘radiate it off’.
Water for example has a specific permeability and capacity on how much charge it can take, before it discharges. Thereby a very big dielectric field is created, composed of these charges, which absorbs water molecules from the ambient, in this special case from the air. The higher the frequency of the triggered molecules, the more charge will be absorbed by the water molecules.
You can even measure how much dielectric charge for example a water drop has got. A simple way here would be the Lord Kelvin water drop-experiment. This link shows a simple way to verify this: [
]Lord Kelvin’s Water Drop Experiment Demonstrator - Science Kit.
One can measure how much dielectric energy a water drop has in its normal condition and after being artificially triggered. These dielectric charges or fields are a great resistance for electrons, current-flow, magnetic fields, etc. or vice versa. If the dielectric field is strong enough, it will repel or ban electromagnetic from its ambient.
The field in the ND was strong enough to block the current flow in the bulb.
The most important to understand is, that our Earth, our atmosphere are full of these dielectric charges, and that they can be tapped and be bundled to a field, which can be used for mechanical work, similar to magnetic fields we use now.
These dielectric charges are monopole (also called unipolar) charges and attract their opposite pole and same-poled charged repel one another. They act like tiny monopole magnets.
If one creates strong (unipolar) dielectric fields they will attract opposite-poled dielectric charges from the ambient, may it be earth or air, or will repel the charge if it same-poled.
These charges are able to transform matter from one element to the other, as for example water to air, whereby water would expands for ca. 2000x. Today we use nuclear power plants to generate heat and steam to produce pressure which runs steam turbines.
Dielectric charges can create the same pressure by converting the element water to air. But it is also possible, but I haven’t tried this, to convert air in the same with dielectric charges to vacuum or gravity fields. I met the engineer of Viktor Schauberger, who still is alive, he was present when Schauberger made these levitation experiments. In the future when time, place and circumstances will allow me, I will try to replicate these experiments, since I already was able to do part of it.
As you can see the dielectric charges can be used for mechanical or practical work.
In my eyes and understanding the bolt of lighting hides the key to free energy. The one who will profoundly analyze this will find a way how to tap dielectric negative energy from the earth.
Best regards,
Shad
