  #4 (permalink)
Old 05-17-2007, 11:21 PM
Peter Lindemann Peter Lindemann is offline
Senior Member
More for Less
Mario,
Thank you for reporting your finding that multiple windings with individual diodes produces more output. The reason that it doesn't work when the coils are paralleled BEFORE the diode is that the energy in one coil tends to discharge INTO the other coil and vis versa. The diodes prevent this from happening, and the energy recovered from both coils can then be summed.
Exactly WHY there is more energy to recover in this arrangement is not known by me. This is simply an experimental result you are reporting. It sounds very encouraging, and I hope others try to duplicate the finding.
One possible explanation is this. John Bedini has been saying for a long time that these devices draw energy in from the environment. Your experimental set-up and finding may be significant evidence in support of this idea.
Also, as to what is "the best recipe?", WHO KNOWS! You state you have a 10 strand multi-coil. Try hooking one strand up as the oscillator and the other 9 strands as extra pick-ups with separate diodes. Keep summing them, one at a time, to see where the benefit ends. That way, you can tell us!
Great work.
Peter
