Thread: Eric Dollard
Old 05-19-2014, 09:53 PM
dR-Green's Avatar
dR-Green dR-Green is offline
Gold Member
Originally Posted by orgonaut314 View Post
Now I do not think that the ground wire could cause a rise in frequency because the wave is generated starting from the primary up in to the secondary coil.
It does. The wire has inductance and capacitance, and the wave doesn't simply propagate within the coil windings as if the the earthing wire is an impenetrable barrier, if it did then there would be no possibility of transmitting anything into the earth.
Ideally it should be a strip/strap and not a wire to minimise the inductance.
