  #160 (permalink)
Old 08-07-2008, 03:28 PM
**~Imhotep~**'s Avatar
**~Imhotep~** **~Imhotep~** is offline
Senior Member
Originally Posted by waterhouse24 View Post
When I used the source batteries as shown in the video i'm drawing 3amps.. but if a swap to the charge batteries I draw around 1.3amps.. I'm going to try swapping different parts 1 at a time now, to see if i can better the ampage draw and keep the same brightness.
Just added the resistor connector that comes with the coil..(bolts on to the + side of coil) and it now only draws 1.57 amps.
Also I unplugged the bulb from the circuit while it was running and the amps only dropped to 1.55, interesting!
Thank you for this research, I was going to test this circuit without the bulb now you have done that and it has confirmed what Peter had said during the initial research. He said that possibly the bulbs are running on a free energy shockwave and he might be right and thus not drawing much of the current. The bulbs are a negative resistor, which means as they warm up the resistance through the gas diminishes. You might have proved this. Excellent work!!
