Old 01-16-2014, 09:21 PM
wantomake's Avatar
wantomake wantomake is offline
Silver Member
test with aluminum sheet
Hello to All,
Found interesting results with aluminum sheet in water.
1) connected wire to pos of #3 battery from aluminum sheet
2) placed car window motor across two neg not pos post
3) no lights on #3 to balance system
While I waited to see #3 drop in voltage and motor start, the primaries voltage started jumping 22 volts to 19 or 20 then back up to 22 again. I tested #2 primary and found it was the one.
So I connected 12vdc light (50 watt) to #3 and the motor started with a surge sound each time the voltage jumped in the primaries 1 and 2.
This happened for five minutes or so and charged the primaries up. But then would start to lose voltage. The #3 would hold around 2.8 volts.
Each time I turn off the motor, let the primary alum batteries sit, they return to 11 volts or so each. I don't recharge them. Then just connect motor and watch the same thing happen. Without light on #3.
Just curious to what you all thought. I did make a video and will post to YouTube later.
wantomake
