Old 01-15-2014, 02:47 PM
Matthew Jones's Avatar
Matthew Jones Matthew Jones is offline
Platinum Member
I have heard it all now. Granite is born out of moisture. Its moist in the mountain, it cut out with moisture, its slabbed up with moisture and it polished with moisture. And moisture is trapped in it.
Its also NOT a solid color. Every part of it is translucent. The stain could be below the surface and give it all kinds of appearance. If you actually etched out the polished surface its because you got battery acid on it. Lemon juice left alone on a granite top will etch it out.
But more than likely if polishing didn't remove it it was moisture. And it went away eventually.
Like I said more housewives than I can count have complained about the same thing. Make a mountain out of a molehill. More of it because they think they are paying way to much for a maintenance free stone that will last forever and never blemish. LOL
Goto any granite shop and get a piece of waste and try it, you'll see Its just moisture.
Matt
ADD BROMIKEY TO YOUR IGNORE LIST He is a saboteur bent on the systematic distraction of every good topic on this forum and since he has been here most working threads have shut down. He is the enemy. If you have blocked him already add this to your signature and encourage others to block him as well. His onslaught of rambling in large text and his constant attempts to misinform at the excuse of being stupid should no longer be tolerated.
USER CP/Ignore list.
