07-25-2008, 10:36 PM
Energetic Science Practitioner
Originally Posted by theremart
Hi Kevin,
Thank you for your pictures... That looks simple enough, I also have used magnet wire for my connections because it is very flexible, and I figured that it has the same resistance as the coil.
I like how short your connections are.
I think I may attempt to replicate this. I am still not sure how you are combining the two circuits as I don't see the underside of the board, but looks very straightforward...
Ok you have a trifialar coil. so this is setup like the standard multicoil Bedni circuit? ( see attached )
Mart
I looked at the attached...greek to me. Aaron would be able to answer that better.
I first wrapped the coil with wire according to the original Bedini SG instructions, then when I went to the two circuits I had to start over and rewind it with TWO power wires (one for each circuit) and one trigger wire.
P.S. Looking at the pic of the coil it does not look very neat...however, I tried very hard to not only twist the wires evenly BEFORE winding them, but also to wind them evenly from right to left and then left to right, etc. I was told that this DOES make a Measurable difference.
