Thread: Radiant Energy
  #16 (permalink)
Old 05-15-2007, 08:53 PM
Shad's Avatar
Shad Shad is offline
Junior Member
Lightbulb
Thank you, Peter, for your detailed reply!
I am not a blind believer, but prefer to really understand things. Allow me to analyze some more this point.
I disagree with you, but this does not necessarily mean that I am right. It's not about my opinion, nor your opinion, but merely about the truth and scientific facts. Discussing with you, is meant to get there, to see the truth from the right angle. If I am wrong, please correct me!
[quote=Peter Lindemann;2397]Shad,
Originally Posted by Peter Lindemann View Post
It creates a "staccato of electrostatic bursts." Don't make this mysterious, because it is not. It is no more difficult to understand than the output of a 555 timer chip. Its just that we are talking about very high voltage DC, and very high pulse repetition rates. What is difficult is finding the circuit components that allow you to create these conditions without self-destructing!
Peter
I think things are not that easy, that we can only talk about very high voltage DC, and very high pulse repetition rates. If it was that simple, we would not have to bother so much about inductive collapses, spark gaps, and could simply take a microwave oven and do the same
Tesla in his writing clearly says that this has nothing to do with AC or DC or very high pulse repetition rates. He describes the properties of dielectricity in neat details and I succeeded to reproduce some of these effects, to also practically convince myself that those were not merely some theories in Tesla's head, but they in fact function that way.
For example, Tesla says when a dielectric or electrostatic spark bolts in an air spark-gap it produces an ark, whereby even the air can heat up and light be caused. He described that light and heat are caused by 'molecular friction' of the air molecules, by charging and discharging. Frequencies with Millions of pulse repetition rates develop here.
My own experiment shows that really light and heat can be developed when an electrostatic spark bolts through the gap. No mystery for me here, rather easy to understand, although I was not really able to measure the frequencies, but I guess it must be quiet high. I even tried to move dielectric transformer oil or veggie oils by electrostatic discharge, as it is described in some of Tesla’s experiments. And – it works. The oil started rotating similar to a tornado. The discharges had a very striking effect on magnetic materials, such as slightly magnetic stainless steel, whereby even the electrodes dissociated. If the electrodes was put into a dielectric liquid, nothing would happen. Especially fast was the dissociation at the weld-seam. A specific kind of non-magnetic stainless steel in these remained unimpaired. Iron wire by the discharge of these electrostatic discharges heated up that quickly, as Tesla described it, whereby the non-magnetic stainless steel conducted without heating up.
Plastic in air will be shot through, like bombed by the sparks, shaving wholes as done by a molecular machine-gun.
So, all this won’t happen with AC or DC high voltage, as Tesla says in his writings – and I tried it, it really doesn’t work.
So, for me it is nothing mysterious if Tesla says that conductive gases, such as air and other should be avoided, because they destroy the material, causing energy losses.
He depicts his air-magnetic spark-gap as a compromise, because there losses are caused. The air molecules are charged and discharged and energy is lost as of light and warmth. He explains that if a better dielectrica was used, which would not allow the energy being ‘radiated away’ as light and warmth they system would be more efficient, which makes sense to me.
Maybe I am wrong, but to simply say scalar waves simply are high-voltage staccato DC, in my understanding is wrong. As you said yourself in your lectures Tesla described that what we understand as electrons are made of much smaller particles. He didn’t mystify and clearly said that current is made out of molecular electricity, positive and negative electrostatic charges. He claimed that if these two charges unite and cancel and if they are moved on, in the orbit a magnetic field will be caused. And this is the magnetic field in our current, AC or DC, or the magnetic field in permanent or electro-magnets.
My question now around these spark gaps was: how to reduce losses in a spark gap without unnecessarily waste dielectricity?
We saw the video from Dollard and it surely all works the way you described it, but I cannot accept that scalar-field are staccato very high pulse repetition rates.
Please don’t take my challenging opinion personal, this merely is a scientific discussion and analyzing with a friendly mind. No negative criticism.
Best of greetings,
Shad
