Old 11-12-2013, 12:10 AM
ElronD_T34 ElronD_T34 is offline
Junior Member
Third Step
Over the insulation we will need to wind aluminum tape like this one : Tape
!!! Important part !!!
We need to wind it as tight as possible BUT WITHOUT turns touching one another !
On the schematic you can see the tape as yellow lines.
There should be ONE LEAD comming from the tape.
As you can see on the schematic - this lead goes to your HV source.
From your HV source - POSITIVE lead goes to the tape , NEGATIVE to the Ground ( We do this to get the amperage , will explain later. )
Now here is the trick . The author says that the voltage needs to be TUNED to a
certain location! And even weather can affect it. So it has to be ADJUSTIBLE.
After the tape should look like so : ( PURPLE is your tape with ONE lead )
