Hi Peter, John, Aaron
I started experimenting with John's technology about half a year ago and at some point I started concentrating on the solid state energizer and am trying to get ..there. I've recently built a new working platform to experiment with single to multicoil setups but is expandable to about 10 multicoils as soon as I figure out wich one is the best of all possible combinations (I attached a pic by the way). In the beginning I thought to simply hook single solidstate circuits in parallel. then I started making some tests with different setups, cap-pulsing, single coil output diode, multicoil output diodes, output with recovery coils, etc... Also after having been working on a multicoil setup with cap pulsing for quite a while, I got much better results with a normal SG multicoil setup with output diodes charging the batts rather than one recovery-bridge cap. Might be because of the lower impedance on the output. Still working on it..so many things to test!
The other day I noticed something new, I was driving only one transistor out of the three hooked to the multicoil, the trigger and base diode were also detached from those two. So while I was running basically off a single setup I accidentally connected the output diode to the output diode of one
of the not running transistors. I could hear the freq go down a bit, like if you lower the trigger pot to increase power (and current draw). But guess what, the input current dropped, while i could measure an increase on the voltmeter on the charging output batt. So I hooked up the third output diode of the also not triggered transistor and the results got even better!
So from an electrical point of view I was driving a single setup and had two "recovery" windings with a single diode each added to it wich gave more output power and took less input current. I always thought that more than one recovery coil wouldn't gain anything..?
I also tried to link the three outputs before the diode, wich didn' give the same results.
Any help or hint to get to the best recipe is welcome!
Peter, I really liked your explanations in the radiant energy forum
, thanks.
best regards
Mario
