Originally Posted by Hrothgar
Are the negatives on the stator the ones with the 2 wires soldered to one post?
there were many types of fans, each one with their own geometry of coil windings. most that ive encountered have dual windings and the post that has two windings connected to it that you separate are hooked up on the original circuitry to the positive end of the source battery. but once u separate them and check cont, between the 4 wires you will find in most cases continuity between 2 of the wires and that will be 1 coil and continuity between the other two remaining ones will become your other coil. it will usually only work one way so if your unit does to work u can try swapping the wires on either the pulse output coil or the trigger coil and get it to work.
