Thread: Radiant Energy
  #13 (permalink)
Old 05-13-2007, 09:58 PM
lighty's Avatar
lighty lighty is offline
Senior Member
Originally Posted by Peter Lindemann View Post
If the capacitor starts at ZERO volts, the first few inductive collapses deliver CURRENT pulses to bring the capacitor up to the voltage level of the source powering the coil. As this process continues, once the voltage in the capacitor gets ABOVE the power source charging the coil, the balance switches, and the coil must start generating more voltage to keep getting above the voltage already in the capacitor. If you have a current probe on your oscilloscope, watch the current pulses going into the cap. The energy of the inductive collapse constantly adjusts to produce more and more voltage and less and less current to keep the capacitor charging up.
Indeed you're right- the effects you're describing are exactly what I was referring to in one of my earlier posts. I called it a "transformer effect" because in those first few pulses when the electron flow is charging the capacitor one can observe that there is anomalous current consumption going on in the "primary". I suspected that it also has something to do with the fact that Bedini is using a full bridge rectifier in his "secondary" and that such configuration is allowing for inductive coupling to transfer energy to the capacitor. I then used only a single diode in order to reduce that effect caused by inductive transfer from "primary" to "secondary". Indeed, a single diode did reduce the anomalous current consumption on the "primary" during the "charging phase" prior to inductive collapse. It's easily seen with the current clamp and fast DSO. It was then that by chance I observed that the negative and positive polarity of the inductive collapse charge doesn't behave the same way. I won't go further into that because I already wrote about that.
But, as John Bedini has shown, if the inductor is totally OPEN to the environment, (no closed magnetic field) the voltage produced by the inductive collapse can easily attain 30 times the level of your power supply. With really good air-core coils, I have seem some of John's oscillators produce voltages 50 times higher than the supply.
In fact 50 times higher voltage is easily achieved if a proper geometry, a proper core material and electronics are used. I can normally achieve a 18V/900V ratio and more is possible but for some reasons of design I have to use the semiconductors in the capacitive discharge circuit and I have to reduce voltage to remain <1kV to prevent a possible semiconductor voltage breakthrough. As I discovered several requirements have to be observed to achieve higher voltage impulses to capacitor and among them is the speed of diode (I use special extremely fast diodes), a semiconductor used to energize the coil should be chosen and driven in a way that would allow for extremely fast shutdown of current through coil and low leakage current after, a high-permeability narrow hysteresis material should be used (I use one form of material similar to Metglas), a precise control of the saturation point of core in order to shut down energizing semiconductor device in the exact moment of highest saturation in order to prevent losses and excessive heating of the components, and finally one should use as high frequency as possible (the coil in configuration I'm using is going up to 6kHz and is limited solely by the inductance of the coil and the time necessary to fully saturate the core). It took me quite some time to get a necessary understanding and control of the processes involved in order to meet all those requirements and still I learn something new every time I try some new approach.
The capacitor can take all of the VOLTAGE you put in it and discharge it in less than a microsecond, creating a HUGE CHANGE of dielectric flux, the quality of which is very low on electron movement. This is the time compressed electrostatic wave.
Exactly! A sudden change of the dielectric flux is what's Tesla was lecturing about and the thing that usually perplexes people is the fact that there is almost no electron movement involved but rather an electrostatic impulse of great magnitude able to produce a some sort of dielectric avalanche in the secondary. Of course that's the underlying principle but several things have to be observed in order for everything to work as described by Tesla such as the proper impulse control, the appropriate sparkgap, the position of the sparkgap in the system etc. I'm just getting into this field and I plan to do several experiments of my own in the near future.
Keep up the great work.
I'm doing the best I can and I can thank you for getting me interested in these topics several years back when I read your articles on MWO published by BSRF and especially with your book The Secrets of Cold Electricity. That was my primer in this field of research so I thank you for writing all down so eloquently and concise.
