Thread: Radiant Energy
  #12 (permalink)
Old 05-13-2007, 06:24 PM
Peter Lindemann Peter Lindemann is offline
Senior Member
Lighty, two answers.....
Lighty,
You are really learning this material, and it is very gratifying to see.
OK, how do you separate the electron flow (current) from the neutral particle flow (voltage)? Believe it or not, Tesla's simple method does it. So does John Bedini's methods. When an inductor is charged with DC current, the intensity of its magnetic field is described by the "ampere-turns" of the coil. When the magnetic field discharges, the voltage it produces is described by the "rate-of-change" of the flux. The flux changes are resisted by themselves, as we have discussed, due to Lenz Law effects.
So, if you discharge your inductive collapse energy into a capacitor, here is what happens. If the capacitor starts at ZERO volts, the first few inductive collapses deliver CURRENT pulses to bring the capacitor up to the voltage level of the source powering the coil. As this process continues, once the voltage in the capacitor gets ABOVE the power source charging the coil, the balance switches, and the coil must start generating more voltage to keep getting above the voltage already in the capacitor. If you have a current probe on your oscilloscope, watch the current pulses going into the cap. The energy of the inductive collapse constantly adjusts to produce more and more voltage and less and less current to keep the capacitor charging up.
Now it gets interesting. IF your inductor has a magnetic field that is completely closed down, like a standard transformer, the voltage level you can charge your capacitor to is only a few times higher than your power source. But, as John Bedini has shown, if the inductor is totally OPEN to the environment, (no closed magnetic field) the voltage produced by the inductive collapse can easily attain 30 times the level of your power supply. With really good air-core coils, I have seem some of John's oscillators produce voltages 50 times higher than the supply.
The question is why? The answer is LENZ LAW! As the capacitor charges up above the supply voltage, current CANNOT be pushed into the capacitor by standard ELECTROMAGNETIC INDUCTION LAWS. There is NO turns ratio gain for voltage production, so all voltage gain is by Tesla's ELECTROSTATIC INDUCTION LAWS. As the current in the discharge drops, the magnetic field can collapse faster and faster because the Back EMF caused by current is diminishing. This INCREASES the "rate-of-change" of flux and the voltage can rise to higher values.
At a certain point, there is no current left, at which point the voltage can rise to VERY HIGH VALUES. This is what Tesla discovered as he scaled these systems up.
So, the coil design suitable to receive the discharge of this capacitor is the primary coil of Tesla's flat spiral or conical coil "TRANSFORMER". That primary coil is always described as "a few turns of stout wire or copper strap." Look at the designs of the coils built by Eric Dollard in the old Borderlands videos. Why? The capacitor can take all of the VOLTAGE you put in it and discharge it in less than a microsecond, creating a HUGE CHANGE of dielectric flux, the quality of which is very low on electron movement. This is the time compressed electrostatic wave. The time-compression is all the time it took to charge the cap is given back in an instant.
The other thing you are seeing is the truth that "electricity is electricity" is a false theory. Electricity can and does appear as a wide variety of different QUALITIES of energy, depending on how the circuit is set up. Only experimental work will show you this. So, again, congratulations.
Keep up the great work.
Peter
