Old 02-25-2007, 07:18 AM
Aaron's Avatar
Aaron Aaron is offline
Co-Founder & Moderator
Custom Avatar
Hi Barb,
The avatars must be specifically uploaded to our server.
However, if you goto the Member List: http://www.energeticforum.com/members/list/
And click on your name, it will take you to your personal profile homepage.
On that page, there is a "block" that is right below the picture usually
and is called the USERNAME block. If you click on the little TOOL next
to the X at the top right of the username block, you can edit this.
In there, there are 3 boxes you can check and uncheck. Keep the
DISPLAY USER NAME box checked, UNCHECK the SHOW AVATAR box,
and CHECK the DISPLAY USERNAME IMAGE.
To the right of that, you can upload a custom image from your computer.
Any custom picture you want. It is a good idea to have this picture fairly
small. 150 pixels X 150 pixels or smaller is a good size for this.
Almost any graphic editing program can RESIZE pics for you.
When that is uploaded, it will show instead of an avatar as long as
the DISPLAY USERNAME IMAGE is showing and then you can uncheck the
show avatar box.
I hope this helps,
Aaron
