Originally Posted by Peter Lindemann
Thank you for opening up such an intelligent conversation. The most important thing here is not to be "right" or "wrong", but that you are learning, experimenting, and thinking deeply about what you are seeing in your experiments! Congratulations.
Well, thank you but I owe that fact mostly to you since it's been your article on MWO published by BSRF which interested me in this area of research in the first place. I really have nothing but respect for your research and for your skills as the talented popularizer of hard to understand topics.
The general "Method of Conversion" is to charge an inductor with intermittent DC current, and collect the inductive discharges in a capacitor.
Indeed it's the basic principle used by Tesla as it's obvious simply by observing the designs of various Tesla oscillators (as he called them himself). There is one thing I observed that is not so obvious at the first look. The polarity of the "fast transient phenomena" of the induction discharge used will to some degree determine the behavior of the system. For example I discovered by experiment that the - polarity of the inductive discharge doesn't behave the same as the + polarity of the inductive discharge. One would think that they're the same because it's the same if you watch either polarity voltage on the oscilloscope but in reality there are some strange things going on with semiconductors when using - polarity of the inductive discharge as well as some very odd behavior of the oscilloscope probe itself. I suspect that grounding of the oscilloscope is interacting with the - polarity of inductive discharge and it causes some serious troubles during the measurement rendering them practically unusable. I alway wondered why Bedini uses handheld oscilloscope. The thing about handhelds is that they should behave much more stable because of their floating power supply is not connected to ground in any way.
Also, if one end of the inductive discharge coil is grounded the transient voltage effect is diminished to some extent or at least changed slightly in it's nature. My guess is that any ground path in the circuit will simply allow the excessive dielectric charge to be leveled out with the surrounding media and thus effectively neutralizing it to some extent. Maybe I'm mistaken but to me it seems only logical.
As I wrote earlier there are some rules that I find must be observed in order to get the better results but I was wondering if you could elaborate some more on the best design of the coils for inductive discharge and on the methods of achieving the highest inductance with least impedance. I mean one could lower the capacitive component of impedance the way I described before but is there some other things that should be observed in order to achieve optimal results?
Your input on this matter would be much appreciated.
