Originally Posted by **~Imhotep~**
Peter Calculated 93 % efficiency during his evaluation ,replication,verification process ,but there is more you guys are going to be shocked!!! i havent sleep in weeks
Imhotep,
Actually, what I calculated was that your method of lighting the compact fluorescent bulbs was up to 93% MORE efficient than the standard method!!! When you can light a 42 watt CFL to near full brightness on 3.5 watts, you are getting the same light with a 93% energy savings. That is what I saw and calculated in the tests.
Honestly, I have no idea what the actual efficiency is, but the savings over standard methods is HUGE! The energy savings seemed to vary with different CFLs, but when the supply and the bulb matched well, the light output for the energy input was FANTASTIC!
I just wanted to clarify what I said.
Peter
PS. Sleep is a GOOD thing. You should try it, once in a while, so you don't forget about it completely!
