Hi Luc,
I'll keep watching your progress. There is already enough info here in this thread to get plenty of people started. I'm happy to send people your way to that thread as I already posted links to it.
I understand that some things like this are just too simple and just pass by the wayside because of lack of belief that it can be that important...I am hoping you and anyone else working on this keeps pushing it like a mad dog on steroids. This method follow the rules of what needs to be in place to unleash an electroradiant event...serious fragmentation of a voltage potential. Spreading a certain amount of voltage potential over a larger cubic area of space.
Understanding the primary principles involved and they are in Peter's Free
Energy Secrets of Cold Electricity book on the Gray Tube technology....they give the insights into everything that is necessary in order to enhance this entire effect, make it more powerful...not worried about efficiency because charging those caps take nothing at all to begin with. If you haven't read that book, I suggest reading it and if you have, then you can see that it describes perfectly what you are working with
My experiments today show me that capacitance is virtually irrelevant and it is all about the voltage. I went up in capacitance for the same voltage...no matter what, the effect didn't improve...and didn't necessarily diminish either going down in capacitance.
Did you say in a vid or posted somewhere you used as small as 2uf capacitor? Or someone else did? That proves the point. What about .1 .01 .001uf at the same voltage. It is all about tuning the gas pressures on the front and back for each system and it probably won't take long for most of it to be worked out. At such small capacitances, they can obviously charge up lightening fast and not only fast but can be charged a long time using watch batteries, AA batts, etc...
People want caps and strobes to play with. Don't buy them. Tell people to go to a grocery store that processes film. Say they're working on a science project and need a haldful of the disposable cameras that already have the film ripped out. They have caps about 120uf and 120v or so plus the battery and charging circuit plus the strobe, etc... I went to one store about 7 years ago and I got about a dozen of them.
Personally, from the simplicity of this, I think the gas production requirements posted by the "gurus" of water gas production are bogus and are meant to distract people from the real secret. Meyer shows in the first patent and last patent about spark discharge and then spark at the plug. With the potential of this method, I can see how it is possible to run an engine on just water vapor, but an obvious enhancement to make it work really easily is that any engine running on it can easily produce a good amount of HHO gas from a booster to add to the moisture. This is where I think it needs to go.
Over all this time, nobody has created enough water gas to power an entire car. All the effort.... even with claims of hundreds of percent over Faraday, that isn't nearly enough. However, the amount people are currently making with everything they have tried *COULD* just be enough already...if they were using Krupas plug...but that may be unnecessary anymore...cost me about $2 for a NGK resistorless plug at Schucks. About $1 worth of diodes. Cars already have ignition systems in the car with the coil and battery and caps are free in those cameras sometimes for the asking. If the potential, no pun intended, of this whole thing is apparently as simple as it sounds...and from collective experience on all these things together, this is an irresistible offer that cannot be turned down.
I hope this rapidly becomes one of the most popular experiments in the world in the "free energy" field. I have a feeling there are more things to surface really soon.
I felt for a long time that the Krupa plugs were the key to unlock it but I don't have the means to duplicate a Krupa plug...the one thing Krupa was quiet about is the "ignition". I chatted with him on yahoo groups off an on the last few years and anytime I asked about the ignition...he stops typing back. lol
With his plug the annode is very large surface area like a mushroom head. If you take x mount of voltage potential and divide it by a certain surface area...there is more ability for it to fragment itself apart than with a small surface area.
Anyway, this is an awesome breakthrough Luc and if there are any further updates that you want to get out to a lot of people, just post them here and a lot of people will see them.
