Hi all been working hard on my 555 timer pulse ss and having some success.
My layout is bi wired coil 555 variable trigger across the emita and base,
the thing is im charging two batterys at different points.
The first charging battery is the standed bedini setup.
the secord charging battery is from the old trigger wire to the 555 battery.
I always thought the trigger on the sg was a waste of energy so by going ss in can use the charge in the trigger!
This solid state can also be used as a sg by using a reed switch to connect the 555 to the E and B. the coil can pulse alot more time with each magnet past like this.
Now im concetrating on the earth battery copper sulphar postive diode and nickel negative. O And condiscaing the batterys.
Hope this helps somebody.
Sorry about he spelling im dyslicsick
