  #91 (permalink)
Old 07-04-2008, 06:49 AM
Sephiroth's Avatar
Sephiroth Sephiroth is online now
Senior Member
Haven't been having great success with the SS yet though gradually improving as I tweak it.
I have a few questions.
Aaron - what is the purpose of the resistor on the negative side of the circuit? Wouldn't that just reduce the voltage supplied to the coil?
Also you have recommended using high capacity caps that are discharged a few volts above the charging voltage. However, I have only ever heard bedini recommend discharging low farad caps at high voltage.
Am I right in thinking that discharging the caps using your system is more like a standard charge and so the batteries can be swapped, whereas bedini's method is more of a radiant charge and so isn't as good at running inductive loads? You said pulsing the caps at high voltage creates a "fluffy" charge, though surely Bedini would have noticed this.
