Thread: Radiant Energy
  #3 (permalink)
Old 05-12-2007, 03:51 AM
Peter Lindemann Peter Lindemann is offline
Senior Member
Lighty, excellent!
Lighty,
Thank you for opening up such an intelligent conversation. The most important thing here is not to be "right" or "wrong", but that you are learning, experimenting, and thinking deeply about what you are seeing in your experiments! Congratulations.
There are two issues here. The first issue is the PRODUCTION of radiant energy and the second is the EFFICIENT TRANSFER of radiant energy.
The first issue is covered by Tesla in his work on the "Method of Conversion", that is, the conversion of "normal electricity" into "longitudinal waves of electrostatic force" otherwise known as Radiant Energy. As I show in my DVD, Tesla's Radiant Energy patents clearly state that Radiant Energy is defined as electrostatic charge CONVEYED by Radiant Matter. Radiant Matter is made up of neutral particles of mass at least 100 times smalled than electrons. The general "Method of Conversion" is to charge an inductor with intermittent DC current, and collect the inductive discharges in a capacitor. Then, discharge the capacitor into another inductor of high self-inductance and low impedance, to raise the voltage even higher for use in lighting systems or stepper type motors. When studying Tesla's "Method of Conversion" it becomes obvious that he was talking about a very broad phenomena. The original diagram shows SIX different processes, all of which produce variations on the Method.
The term "Radiant Energy" evolved from Tesla's friendship with and admiration of Sir William Crookes. Crookes invented the Radiometer, a device Tesla referred to as the most elegant motor ever devised. Crookes was studying the effects relating to the emissions from incandescent matter. The question was, when a piece of mass is heated to the point where it starts to emit light and heat, what EXACTLY is coming out of the matter that conveys these properties into the surrounding space? The Radiometer demonstrated that these emissions had MASS and could convey a PHYSICAL FORCE to another object. Tesla came to believe that ANY source of light and heat, such as the Sun, was emitting "whatever" is emitted when MATTER RADIATES! Whatever that was, was termed "Radiant Matter." Since it could go right through the glass enclosure of the Radiometer WITHOUT disrupting the vacuum inside, the determination was that the particle size was INFINITESIMALLY SMALL. Tesla's later experiments determined that these Radiant Matter particles where the primary CONVEYOR of electrostatic charge.
When I can, I will discuss the second issue you bring up.
Peter
