If You Value Your Health
I really love this new article by Dr. Young.
The only thing I would change is his use of the term lifestyle choices.
It's not really our choice that tap water is too acidic, or the air we
breathe, or that dr.'s prescribe things which add to our acidity, or
that salt is processed which messes it up, or that so much available
food comes with that already in it.
From the research I've done on this the #1 way to deal with this is by
adding a scoop of alkalizing powder to milk, soy milk, whatever once a
day. Of course there's additional things you can do. Jessica
__
In this very revealing and thought-provoking
presentation, Dr. Young helps us to to take a
clear-eyed look at how illogical current medical
thinking is about diagnosis of symptoms, naming
diseases, and then prescribing drug treatments.
If you want to know the real "CAUSE" of some
common dis-ease and disease conditions, read on!
"Disease or should we say Dis-ease names like cancer,
diabetes and osteoporosis are misleading and misinform
patients about dis-ease prevention.
There is a curious tendency in conventional medicine
to name a set of symptoms a disease. I was recently
at a compounding pharmacy having my bone mineral
density measured to update my health stats. I
spotted a poster touting a new drug for osteoporosis.
It was written by a drug company and it said
exactly this: 'Osteoporosis is a disease that causes
weak and fragile bones.' Then, the poster went on to
say that you need a particular drug to counteract this
'disease.'
Yet the language is all backwards. Osteoporosis isn't
a disease that causes weak bones, osteoporosis is
the name given to a diagnosis of weak bones. In other
words, the weak bones are the result of excess acidity,
and then the diagnosis of osteoporosis followed.
The drug poster makes it sound like osteoporosis
strikes first, and then you get weak bones. The
cause and effect is all backwards. And that's
how drug companies want people to think about
diseases and symptoms: first you 'get' the dis-ease,
and then you are 'diagnosed' just in time to take
a new drug for the rest of your life.
But it's all an illuision. There is no such
disease as osteoporosis. It's just a made-up name
given to a pattern of symptoms that indicates
you are over-acid which causes your bones to
become fragile.
As another example, when a person follows an
unhealthy lifestyle that results in a symptom
such as high blood pressure, that symptom is
actually being assumed to be a disease all by
itself and it will be given a disease name.
What disease? The dis-ease is, of course,
'hypertension' or 'high blood pressure.'
Doctors throw this phrase around as if it
were an actual dis-ease and not merely
descriptive of patient physiology.
This may all seem silly, right? But there's
actually a very important point to all this.
When we look at symptoms and give them disease
names, we automatically distort the selection
of available treatments for such a dis-ease.
If the dis-ease is, by itself, hypercholesterolemi a
or high cholesterol, then the cure for the dis-ease
must be nothing other than lowering the high
cholesterol. And that's how we end up with all
these pharmaceuticals treating high cholesterol
in order to 'prevent' this dis-ease and lower
the levels of LDL cholesterol in the human patient.
By lowering only the cholesterol, the doctor can
rest assured that he is, in fact, treating this
'disease,' since the definition of this 'disease'
is hypercholesterolemi a or high cholesterol and
nothing else.
But there is a fatal flaw in this approach to
disease treatment: the symptom is not the cause
of the dis-ease. There is another cause, and
this deeper cause is routinely ignored by
conventional medicine, doctors, drug companies,
and even patients.
Let's take a closer look at hypertension or
high blood pressure. What actually causes high
blood pressure? Many doctors would say high
blood pressure is caused by a specific, measurable
interaction between circulating chemicals in the
human body. Thus, the ill-behaved chemical
compounds are the cause of the high blood pressure,
and therefore the solution is to regulate these
chemicals. That's exactly what pharmaceuticals
do -- they attempt to manipulate the chemicals
in the body to adjust the symptoms of high blood
pressure. Thus, they only treat the symptoms,
not the root cause.
Or take a look at high cholesterol. The conventional
medicine approach says that high cholesterol is
caused by a chemical imbalance in the liver, which
is the organ that produces cholesterol. Thus the
treatment for high cholesterol is a prescription
drug that inhibits the liver's production of
cholesterol (statin drugs). Upon taking these
drugs, the high cholesterol (the 'disease')
is regulated, but what was causing the liver to
overproduce cholesterol in the first place?
That causative factor remains ignored.
The root cause of high cholesterol, as it turns
out, is primarily an over acidic lifestyle and
diet. A person lives an acidic life or who eats
foods that are acidic will inevitably cause the
body to go into preservation mode and produce more
cholesterol to neutralize the excess acid thus
showing the symptoms of this so-called dis-ease
of high cholesterol. Its simple cause and effect.
Eat the wrong foods and don't exercise, and you'll
produce too much acid which will cause the body to
release cholesterol from the liver to bind up
that acid which can be detected and diagnosed by
conventional medical procedures. You see it is
not the cholesterol that is bad it is the acid
producing food we eat and the lack of exercise
that is bad. Reduce the acid producing foods
like beef, chicken, pork, dairy, coffee, tea,
soda pops, etc., and start exercising every day
and you will reduce the protective cholesterol
that is saving your life from acids that are
not being elimnated from an acidic lifestyle
and diet.
Yet the root cause of all this is actually poor
lifestyle and food choice, not some bizarre
behavior by the liver. If the disease were to
be accurately named, then, it would be called
Acidic Lifestyle and Food Choice Dis-Ease, or
simply ALFCD.
ALFCD would be a far more accurate name that
would make sense to people. If it's an acidic
lifestyle and foods choice dis-ease, then it
seems that the obvious solution to the dis-ease
would be to choose a lifestyle and foods that
aren't so acidic. Of course that may be a bit
of simplification since you have to distinguish
between healthy alkaline lifestyles and foods
and unhealthy acidic lifestyle and foods. But
at least the name ALFCD gives clients or patients
a better idea of what's actually going on rather
than naming the dis-ease after a symptom, such
as high cholesterol. You see, the symptom is not
the dis-ease, but conventional medicine insists
on calling the symptom the dis-ease because that
way it can treat the symptom and claim success
without actually addressing the underlying cause,
which remains a mystery to modern medicine.
But let's move on to some other dis-eases so you
get a clearer picture of how this actually works.
Another dis-ease that's caused by poor lifestyle
and acidic food choice is diabetes. Type 2
diabetes is the natural physiological and metabolic
result of a person consuming refined carbohydrates
and added sugars in large quantities, undigested
proteins from beef, chicken, and pork without
engaging in regular physical exercise that would
compensate for such dietary practices.
The name 'diabetes' is meaningless to the average
person. The disease should be called Excessive Acid
Dis-Ease, or EAD. If it were called Excessive Acid
Dis-ease, the solution to it would be rather apparent;
simply eat less sugar, eliminate all animal proteins,
eggs, dairy, drink fewer soft drinks, exercise and so
on. But of course that would be far too simple for
the medical community, so the dis-ease must be given
a complex name such as diabetes that puts its
solution out of reach of the average patient.
