Old 11-28-2012, 11:27 PM
Dave45 Dave45 is offline
Platinum Member
Hey MM good to read you too bro
I wound a six filar and connected them individually so as to cancel the magnetic field, the resistance went way up I havent done any measurements but running 12 volts at 2 amps barely lights a 12 volt bulb, if I bypass the coil the light shines bright.
I may play with this a bit, I thought of winding a secondary over this coil and pulse through the secondary with a function gen just to see what I can pick up.
I put the cell back in with 12 volts ac, should be ready tomorrow.
