Old 11-07-2012, 08:39 PM
Harvey's Avatar
Harvey Harvey is offline
Gold Member
Originally Posted by stevenv9179 View Post
Hello, im curious as to why they need a alternating pulses to split water as opposed to two static electric fields on opposite ends. Would the static fields pull apart a water molecule.
Thanks and all the best
If you think about it, using a static field would be similar to trying to separate two magnets from each other by placing them in a larger (and higher density) magnetic field.
The magnets would no doubt choose one polarity or the other and migrate toward that pole depending on location and orientation. In a similar way, water molecules would react in a static E field, propagating toward the attractive pole.
What would be required to cause the two magnets to separate using only magnetic force to do so?
