I have a 2007 Toyota Prius which I have been very happy with. I have averaged better than 54 miles per gallon of gas used, with no modifications to the original design. In looking ahead, though, I would like to be able to nearly eliminate the need for gasoline, and be able to run mainly with the electric motor. As a test, I took the Prius out on the highway at a speed of 65 miles per hour, and allowed the engine to run out of gas. I wanted to see how far I could then proceed on the 67 hp electric motor alone before the battery pack was depleted. I was able to go only 3 miles before this occurred, even though I slowly reduced my speed. I have read about conversions that replace the stock Panasonic 202 volt, 6.5 Amp-hour, 168 cell nickel metal hydride battery with one of greater capacity, and that utilize a home plug in attachment to maintain a relatively high charge prior to departing on the road, but such conversions are very expensive. One man I read about shelled out $32,000 to convert his brand new Prius. Also, once the higher capacity battery loses about half its charge, the gas engine will then kick in and work harder to maintain the charge. I have thought about Hydrogen boosting, as I currently do with my Mazda pickup truck, and that would definitely get me more miles per gallon. Even with Bob Boyce's Prius installation, though, he only achieved around 60 mpg at best. So I am wondering what might be the most cost effective way to keep my stock Panasonic battery optimally charged without relying on the gas engine. The Prius is designed to keep the battery charged to between 40% and 60% of capacity, as that provides for longest battery life of about 10 years. This also provides a reserve capacity to store energy from regenerative braking, which is important in the Prius. The Prius system actually uses two motor/generators to provide both motive and regenerative power. So without changing any of that, it seems that if I could maintain the battery at say 55 percent of charge with some added charging device, the gas engine would not need to kick in at all, except for high speed, hill climbing, and acceleration assistance requirements. For those reading this post, what would you suggest as the most cost effective method of maintaining the battery charge? Perhaps a self-oscillating solid state device? I'd love to hear what John Bedini, Tom Bearden, and Peter Lindemann would suggest, and I welcome thoughts from all interested forum members.
My best regards to all,
Rickoff
