Old 10-14-2012, 03:38 PM
darkwanderer darkwanderer is offline
Junior Member
Originally Posted by 5150 View Post
so in theory the longer the arms are with the weights the more power output that can be generated? But the flaw in this is that at some point the wheel itself will have to be enlarged to handle the extra gravity forces so that means at some point the theory basically indicates that you are still limited to some degree.
also you mentioned there being more torque on one side, does that off balance torque then create other issues such as unbalanced wear or stress on that one side or over the entire system?
The system seems to have limitations cause of the size. Mikhail's system was very big. That's why it generate lot of power. So for more output the system must be enlarged...
Yes that's another problem. System has to be strong enough to handle the stress etc...
