  #2 (permalink)
Old 06-14-2008, 11:56 PM
henrii's Avatar
henrii henrii is offline
Senior Member
Detox
Originally Posted by future pather View Post
I've been using a non-invasive product to remove acidic toxins.
It is a pad that you put on the bottom of your feet while you sleep.
There are knock-offs of the product I am using that are proven scams.
( Acuped Test Results - Acuped Detox Foot Pads )
I am using Acuped Pads. I find in the morning they have turned from white to dark brown.
I think the scam ones do that no matter what. But with Acuped pads you are supposed to use them until the brown no longer appears.
Used pads have been shown to have lead and arsenic in them.
Although there is a button on the Acuped pad website that says affiliate program, apparently that is for other products. I have been told there is no affiliate program for Acuped pads
However, the more you buy the less they are.
I am getting ready to buy some more.
If anyone else is interested in using the product, please let me know here. I may buy more and then re-sell them to you for less than you could get by buying directly (depending on the quantity you want).
There is another similar product offered by the same company that has some additional perks. It has a metallic backing (the side that goes against the adhesive, not your foot) so there is more heat for pulling toxins and one other ingredient that pulls toxins.
Order Detox Patch with NEW Heat Reflector!
You can get two free pads from that site if you want to try them.
Even if you are going to do that first and decide later about getting more, please let me know you may be interested. I will use any responses to gage what quantity I will buy for my next purchase.
Also indicate if you have a preference between the Acupeds and the Life Detoxes.
Jessica
Hi Jessica,
My experimental healing device is supposed to detoxify and energize you at the same time. But I'm currently upgrading it re more vitality boost.
You can read it here.
Exchanging services
Thanks for the info!
Henrii
