Old 09-23-2012, 10:16 PM
drak drak is offline
Senior Member
This page might explain a little more.
How can make it work a perpetual motion machine?
I. Define, for a start, with the source of motive power, input and output devices.
1. The source of the driving force is the Earth's gravitational field, which is similar to the electromotive force (EMF) can be represented as massodvizhuschuyu force (mDS).
This representation is appropriate, because the gravitational field acts on any material object, including those charged. Power of our source mDS unlimited. But to use in practice, we can only the part which will provide the working masses, creating the workflow.
2. Output for all devices of this type is the axis or shaft, mounted in the supports on which they have to rotate and which can be connected to the payload.
3. As an entry must be selected element or elements of the device, the impact of which can alter the shoulders of forces so as to form a resultant torque of the device as a whole.
In our case, these elements are the flip side spokes, pivotally attached to the fixed parts of the spokes of the shaft.
II. In addition, constructive implementation unit should allow the accumulation and preservation of the greatest possible difference between the moments of forces on the right and left sides of the wheel, that is, the presence of elements from the memory effect.
In this device, such an element is joint with emphasis. It should be noted that many inventions to date devices of this type are elements in the structure have (container with liquid accumulated and discharged from different sides of the wheel, for example).
III. Another important omission is all the developers of these devices is a small (insufficient) number of work items (goods on the spokes, filled with liquids, etc.). In this case, a small net moment of forces may be formed, but it is "eating" the friction loss. The maximum value of the resulting torque can be obtained by increasing the number of elements to achieve the value limited by the capacities of the practical implementation of the device.
Not required for this forget operate at a higher power output of a single device at any cost. Because you can get more power parallel connection of smaller devices with lower structural complexity and cost.
IV. God knows who came up with the idea that the wheel of perpetual motion (gravity) can and must rotate at high speed. But this is a misconception firmly established in the concept of how it works
So - basically can not and therefore should not.
Optimal speed mode with loads of HP - Kettlebell operation hours, barely distinguishable from the statics. The speed of rotation of the Ferris wheel is also suitable.
By the way, with a little modernization, it can be converted to a demo version of the giant HP.
By increasing the effective speed resulting torque is reduced, because the wheels on the side where the goods go down, the weight is reduced, and on the other side of the wheel where the goods go up, their weight increases (a manifestation of the inertial mass). The centrifugal forces of goods increases with increasing speed, also have a negative effect on the performance of HP, until the complete violation of his performance.
V. Taking into account the effects of the input device, the static distribution of the forces should form a resulting torque of the device at any time.
In this case, the condition k> 1 (the device over - single mode).
Otherwise, the device will not function.
So, with the requirements and conditions of the gravitational engines (the eternal, of course), we decided.
