Old 09-23-2012, 03:15 AM
Farmhand Farmhand is offline
Platinum Member
Not enough Data.
I see 1500 watts on the meter is that the input ? Because if it is it means very
little. If the 1500 watts is the output then why show the heater power rating ?
The rating on the heater is for maximum heat setting the minimum setting will be
less, probably less than half of the rated power. Also the grinder spinning with
no load should use much less than the rated power.
What is needed is the output energy dissipated, and the input energy in real time.
There is no way I can see to know what is what in that video.
