lighty,
there are two wires wound parallel on each pole. The turn count is 25 for each wire. The winding process was so hard that I did not bother to wind the coils with all the layers with the same winding count. You can see this in the following picture:
I just started at the point nearest to the stator and wound till the end of the pole, then reversed the direction and wound backwards. There are more turns on the stator end of the pole. The first layer was 7-8 turns (if I recall correctly) and each next layer had fewer and fewer turns.
