Old 08-27-2012, 09:36 AM
pmazz850's Avatar
pmazz850 pmazz850 is offline
Senior Member
Prochiro,
Thanks for the info and the pics. I will have to make a larger core as I don't seem to have enough room to stack all the wire on the sides going up to the fins. I was able to wind one layer but no room for second layer on the way back.
@UFO,
What I asked was about "layers" not "filiar". I was using two strands to wind but like said above I don't have the room to wind the second layer coming back.
I haven't made any real tests with the seven pole. I have to order another pair of motors to modify. I did just make two end caps that house the brush assy's. that can be rotated the amount between the stator magnets.(size of the gap) also have to shim one end to eliminate a slight vibration with new end caps. I'll post a pic for you later.
Regards.
