Old 08-05-2012, 09:35 AM
Michael John Nunnerley's Avatar
Michael John Nunnerley Michael John Nunnerley is offline
Gold Member
read what I said!
Originally Posted by shylo View Post
Overunity is possible but you can't use it???
shylo
Do not change my sentance, quote what I said and do not change it. I said USUALLY IT IS TOO LOW IN POWER (watts), and then I went on to say that if you can add in real power in the form of current then you can have a usable gain. Power (watts) = current (amps) X EMF (volts), 100 watts = 100amps X 1volt, 10kw = 100amps X 100volts.
If you can charge a battery over a period of time with very low current, you can then use that battery at high current output for a lesser period of time than it took to charge it, BUT, the time power factor shows a gain to what was used to charge it.
Mike
