Old 07-23-2012, 04:22 PM
Bizzy's Avatar
Bizzy Bizzy is offline
Senior Member
Originally Posted by boguslaw View Post
UFOPolitics is working on it I believe. The last I saw something like that was a patent from 70'ties or 80'ties.I will check if I could find it again. Basically motor-generator with two commutators or commutator and slip rings. The idea is to simply get the power from "generator" stage of motor and put back to stator coils. I will be back to this concept in the future, mechanical devices are not something I like the best (more chances for failure). Surely it can be done after eliminating Lenz drag.
Hi Boguslaw,
You are correct when you say that you simply need to get the power from the generator to the stator/motor. And you are also right when you say thayou need to eliminate Lenz's law. that is what I have been able to do with my unit. I first isolate the alternator from the motor by using my transfer swicth. I eliminate Lenz's law by adding a capacitor at the motor so there is a continual flow of power to the stator/motor the only draw back to this is that it also eliminates any back emf
Bizzy
Smile it doesn't hurt!
Jesus said,"...all things are possible through God." Mk10:27
