Old 07-13-2012, 04:46 PM
john_g john_g is offline
Silver Member
Originally Posted by b_rads View Post
Hope this is not a stupid guestion? When winding the 2 series poles, is one pole wound and then the complimentary pole or are they wound in a figure 8, winding both poles together? Very exciting and thanks to all who are sharing.
Brad S
Hi Brad S
You wind one side to the point, then with the same wire wind the other from the point. So as you look at the windings from the shaft end you have a north on one side and a south on other. I have to say I found it very frustrating to wind (not that I have much experience of motors) because its so small.
Dana, I think you are correct, as I say its the same way viewed from the shaft end, (over the top, return under) otherwise viewed side on, one is CW the other CCW.
John
