Old 07-12-2012, 03:48 AM
Ufopolitics's Avatar
Ufopolitics Ufopolitics is offline
Platinum Member
Hello Wonza
Originally Posted by wonza View Post
I already have some of this wire, will that work ok?
When you say weld, will a standard soldering iron suffice, or is some arc welding required?
Can these devices be self-running with no outside power? (even if an initial input is required), by somehow connecting the output back into the input.
That wire will work just fine...28 and 30 awg is just a hair away...
Those little motors could be solder with a 30 Watts Iron...but it will take longer to heat the metal to the point of melting the solder, scrape it good to clean it before...do not melt the solder with iron...but try on right next to it but on body of motor metal, till it starts melting...then melt it right on crack area...must put it on a vise...Now, you could use the Q-Bond I mentioned on your magnets thread...that works great. Or any other fast glue like crazy glue...it will not be for ever though...
No device could be a self runner just like that Wonza...that you just hook out to in and vuala...sorry...there are more things involved my friend...caps, tronics...delay circuits...etc
