Although I've had some luck charging using the 6 garden lights in series, it seams to be a fluffy charge, as there is only 25mA of current to charge with, even though there are 14 volts.
So, I'm going to change the wiring to 3 solar cells connected in series, and 3 in parallel. To see if I can charge a 4 volt 2ah lead acid battery, which are actually 4 separate 4 volt 0.5ah batteries all connected in parallel.
Any suggestions are always welcome.
