Old 06-28-2012, 07:48 PM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
Originally Posted by llynch View Post
Vibrations, vowels and visual patterns.
Rough draft of text that ties the harmonics together as well as musical notes. Creating the image above caused the text below.
Buddhist monks chant(repeat mantras).
Which consist of what can be called English vowels.
Which are intonated for a specific duration, in a specific pattern and specific number of repetitions which is likely dependent on a specific goal. (at this point in research are unknown)
Maximum energy is transmitted via resonance.
(begin: my personal perspective)
Energy flows through the body.
It's mental representation is the sub-conscious(or subjective mind created via the interaction of the energy with the pineal gland).
The purpose of the chanting appears to be bring the conscious(objective mind) into greater harmony with the sub-conscious(subjective mind).
This being done by using lower frequency harmonic resonance while in a meditative state.
(end: my personal perspective)
Below is an example of the relationships between various frequency ranges/scales. As well as links to calculators to determine the harmonics that lie in the different frequency ranges/scales.
Each person being formed differently will have slightly different resonate cavities in their head. This will require a person to record themselves sounding the vowels followed by using software to determine the frequencies of each. Youtube has many video's describing the proper techniques of intonation to achieve maximum cranial resonance. These personal vowel frequencies could be considered your fundamental/resonant frequencies in an odd way.
Vowel = Freq. Hz = Musical Note = Harmonic in the UV-A Light range. nm
A "AH" = 95 Hz = F#1 +46.20 cents = 357nm through 360nm
O "OO" = 99 Hz = G1 +17.60 cents = 343nm through 346nm
E "EE" = 101 Hz = G#1 -47.77 cents = 336nm through 339nm
UV-A Light Range 380nm-315nm (just above the visible light spectrum)
Piano:
Octave: a term indicating a repeating pattern of 'frequencies' at different 'scales'.
There is a C note in each Ocatve
The note C is always C regardless of what scale/octave you are at.
Just as the note C is a C at each scale. The vowels A, O and E are the same when at the higher frequency scales of the light spectrum.
If still curious, there are likely harmonics within the lower Schumann Resonance frequency range as well as matches of Chlandi visual patterns with the patterns created by pendulums.
Reference for the 3 vowel frequencies:
Harmonic Content of Vowel Sounds
Source of the Harmonic/Sub-Harmonic Calculator:
Spread Sheet Calculators
Source of the Wavelength to Frequency Calculator:
Downloadable/Web Flash based EM Spectrum application:
EM Spectrum - e-motiv attic (download)
Frequency to Note Calculator:
just adding complementary info
Originally Posted by purelyconstructive View Post
For those that are familiar with their work, it is related to Walter & Lao's Doubly Charged Spheres and Still Magnetic Light. It also demonstrates clearly their concept of "like attracts like" (Attraction = Resonance).
And thus we Return to the Notion of Cymatics with grains of Sand :
Cymatics - Bringing Matter To Life With Sound (Part 1 of 3) - YouTube
if you observe closely , you will notice that the "spheres" of like sizes tend to clump together
here : 2 min 50 sec
Cymatics - Bringing Matter To Life With Sound (Part 2 of 3) - YouTube
remember: Principle of Polarity and Principle of Gender ;when you watch )
and remember the Monks moving Granite with their Sacred Chant:
STEVEN HALPERN Cymatic Imagery of Sacred Chant recorded Inside the Great Pyramid - YouTube
now visible
Know, therefore, that in the hen's egg is the greatest help with respect to the proximity and relationship of the matter in nature [B], for in it there is a spirituality and conjunction of elements, and an earth which is golden in its tincture. The Golden Tractate of Hermes Trismegistus
Thank you Llynch ... great post
Signs and symbols rule the world, not words nor laws. -Confucius.
