  #12 (permalink)
Old 05-07-2007, 07:36 PM
Peter Lindemann Peter Lindemann is offline
Senior Member
Answer to Shad from Peter
Originally Posted by Shad View Post
Hi Peter
I just joined the group - looks like something good among all the groups
Shortly ago I studied your lectures carefully which were really inspiring and made me thinking! Thank you very much for sharing your knowledge with us!
I often wondered how Bedini charges his batteries - in my eyes he is the master of radiant energy.
I don't understand much of the electronics but rather the physics behind it and am convinced that with his energy spikes/back-emf he causes a radiant event in his battery, which causes the battery to recharge. How he causes this radiant event, is his secret, but it surely is not enough to shoot back-emf into the battery...
Actually, batteries aren't really charged, that is some kind of wrong understanding. What is really happening there is that a kind of electro plating occurs while a battery is charged with current. In his process Bedini causes an avalanche effect of radiant energy in the batteries, similar effects were reported in Tesla's works. However, a battery is no capacitor that stores energy, but there rather occurs an electro-chemical process, which might be mis-interpreted by electro-techniques.
If two different kind of metals are put into an electrolyte, the electrodes will generate ions, or in better words, dielectric charges. If we short out the electrodes and the current starts flowing, electro plating occurs whereby the electrodes start dissolving and exchange each other.
If one charges batteries, a vice versa process is done - and once the electrodes have recovered, we use to say the batteries are charged, because they give power again.
Peter, I have a question to you - what do you think would be happen if we took the ions/dielectric charges in some 'indirect way' away from the battery, without using and destroying the producing electrodes?
Imagine in the same electrolyte you would have two neutral electrodes, made from the same material, like non-magnetic stainless steel. We need the same material in both electrodes because in this way we do not produce any ions/dielectric charges. If now these two electrodes would be shortened out in pulses, they would have to polarize and some current would flow through them.
In this way it would be possible in some indirect way to tap electricity from the battery, without destroying the electrodes that produce the ions and electricity.
But what would be used here was the water, as every time electricity comes across the electrodes an electrolysis would occur. Then water would have to be refilled, whereby the electrolyte is not being used up.
In my eyes the greatest problem is that we use batteries in a wrong way and that we have a wrong understanding of electricity. We always destroy the electricity source - if we had a way of taking it in an indirect way, we would have plenty free electricity and hydrogen from a so-called electrochemical process.
What do you think? Or am I too creative?
Well, my English sometimes sounds weird, but I hope I made my point clear...
Best wishes,
Shad
Hi Shad,
Your speculations here are generally correct! It is possible to make a cell with different metals that produces electricity with NO chemical changes occurring on the plates. Such a device is, technically, NOT a battery, but such things DO exist. They are the best proof that REAL electricity is NOT the movement of electrons. Lead-acid batteries do require some electron flow to function properly and John's chargers produce the right mix of Radiant Energy and electron flow to optimize the battery process.
I have witnessed a number of circuits that John has produced that blocked 99% of the electron flow. The output of these circuits can light light bulbs and when applied to a battery, it looks like the battery is charging, at first. But very shortly thereafter, the battery blocks up and stops working. In small gel-cell batteries, the electrolyte dries up within 24 hours and the battery is dead. Even in large, flooded cell batteries, the process takes longer, but the result is the same. The battery becomes useless and can never be charged again.
The circuits that do these things are VERY counter-intuitive and no one is likely to stumble into them by chance. These discoveries only became apparent after extended study by John.
Theory can only get you so far. At some point, experiment must reduce theory to practice for knowledge to be advanced.
Peter
