  #11 (permalink)
Old 05-07-2007, 06:38 PM
lighty's Avatar
lighty lighty is offline
Senior Member
Originally Posted by Shad View Post
A nice example here is exotic matter, such as mono-atomic gold, also called ORMUS, which you can find googling. This material seems to be a great mystery for science, but one scientific fact is that it is very closely connected to gravity and zero point energy. The laws of thermo-dynamics here do not seem to have any influence on this exotic matter.
It's interesting that all of the "electrical healing systems" employ one or other kind of dielectricity. I did a lot of work with Rife system and I also did some small amount of work on Lakhovsky system. The common thing is that when you remove the magnetic component of the radiation what's left is a dielectric field which seems to have potent healing potential. The same thing happens with the Schauberger "energized" water. The more interesting aspect is the experiment done by BSRF (or at least I've read about it in one of their journals) regarding a plant growth in the complete darkness. The system used was pretty much similar to the Tesla patent on the radiant energy but the plants were kept between the plates of what was basically the capacitor. I personally witnessed operation of basically similar system of healing with dielectric field in Russia and let me tell you it heals a lot of ailments usually deemed as un-curable. They also employ a system where a sudden and short high potential spikes (in potential range of 3-4 kV) of extreme short durations are applied directly through body. That device also has a tremendous healing potential and it something to think about when considering electric healing systems like Hulda Clark's where a square wave output is applied directly to body tissues- well, if such small impulses and negligible back-EMF generated are able to help healing then imagine what a Russian system might do. Of course there is always more to that then it's being told as my hosts made sure I was aware of.
But what will happen if besides the ‘normal’ electrodes, one additionally inserts neutral electrodes that do not produce any charges, but would be able to tap the surrounding charges in the electrolyte of the battery? The electrodes that generate the charges would thereby not degenerate, because there is no electro-plating.
I think that in this case you would basically get something that Frolov calls "an information providing". It means that you only have to provide some open loop system with the information that the energy is available in order to get the system to react (or at least that's how I understand it). The other way of putting is that you only need to provide the potential and then not allow the system to destroy or rather discharge that potential directly. Bearden says something along that line also although with different terminology. It's pretty much similar to the voltage appearing between the electrodes of the asymetrical capacitor placed between two magnetic monopole beamers like used by Bushman. There is no direct magnetic induction involved but rather an indirect potential appearance caused by the dielectric field appearing in between interacting magnetic monopoles.
The recovery of the electrodes can also happen without electrolyte, as for this merely is the bombardment of radiant spikes is needed.
But I could be wrong… I guess John Bedini is the only one that could say what is right or wrong, as he is the inventor of such battery charging system with radiant energy.
As I said earlier- Bedini himself mentioned this effect in one of the references of his book. I take down my hat to Bedini, he really is one of the great ones. Or at least one of the ones we've heard of.
The water was that much charged with dielectricity that it combusted better than diesel, gasoline or kerosene, even better than hydrogen/oxygen from electrolysis.
The further step would be the combustion of air itself and if I recall correctly there is a Russian patent issued on that matter. The team from Russia supposedly succeeded in producing a "carburetor" system that allowed air to get to the point of self-combustion. Although I don't have any further info on that one I suspect that they simply oversaturated atmospheric air (rich with Nitrogen) with dielectric charge to the point where it started to combust on it's own. I remember Tesla saying that combustion of matter or gases is nothing more than a release of electrostatic energy from the matter. In fact with some of his coils he demonstrated discharges that produced what appeared to be white flames of extreme temperatures. In fact Jeff Behary reproduced one of his coils and got the same results.
So, if we understood dielectricity better, we could make a handful of miracles 
Indeed.
Thanks to pioneers like Tesla, Keely, Schauberger, today’s people like Tom Bearden, John Bedini, Edwin Gray, and those who share their knowledge here, as Dr. Peter Lindemann it is much more easy for us to understand as they have done the spadework!
Bedini/Bearden duo is indeed something to be reckon with and Peter Lindemann is the guy who is extremely good in popularizing stuff that is otherwise somewhat hard to grasp.
