Old 06-03-2012, 07:27 PM
Guruji Guruji is offline
Silver Member
Originally Posted by boguslaw View Post
Yes, indeed it is hard to get it running especially with low voltage like 12V input. I checked that it runs by using simple device : one turn of wire attached to AV plug and then to LED. LED is lit near the running kacher and even 1.5m far from it. Also the ac/edge electronic detector is indicating field exactly like Don Smith presented in his 2001 video. I have managed to get a nice violet plasma about 1cm long but many times it require then you touch the output wire with a metallic object or ground connection. It looks very nice like a small laser saber. Of course it works if you place coil vertically and output is not attached to any larger diameter wire.
Thanks Boguslaw I will try with higher voltage. Regarding the wire around the battery it should be done as a plate yes? I mean all wire shorted.
