Old 05-31-2012, 07:58 PM
boguslaw's Avatar
boguslaw boguslaw is online now
Gold Member
Originally Posted by xee2 View Post
The upper frequency limit is set by coil self resonant frequency. To lower frequency put capacitor in parallel with either coil. If transistor is not fast enough it can limit frequency also. MJE13007 should work up to several MHz.
Thanks.Seems I resolved problem by placing irf630 between emitter and ground of mje13007 and driving it from oscillator type. Because I'm not good in electronics it took me two days to construct circuit and probably will take another two to make a board in copper. I wonder if I can check the output waveform somehow without damaging scope ?
